10-30-2020 05:28 AM
11-04-2020 01:40 AM
11-04-2020 02:13 AM
11-04-2020 05:59 AM
Christine_ASUSmany MPM2 users have already said that even after changing earpiece or updating to A10 problem is not solvedI suggest there is a high possibility of faulty hardware, device or earphones. The sound performance of my device in Android 9 and Android 10 works properly. Normally 30% volume while using the earphones is really loud for me. If you suspect any software issue like 3rd party apps, you can give the Factory Reset a try.
11-04-2020 07:05 AM
abhaykrishnan02I think (ZB631KL) NFC variant doesn't have problem.https://zentalk.asus.com/en/discussion/comment/130231#Comment_130231
11-04-2020 05:19 PM
abhaykrishnan02Hi abhaykrishnan02https://zentalk.asus.com/en/discussion/comment/130231#Comment_130231
