Model Name: Asus Zenfone Max pro m2 (ZB630KL)
Firmware Version: QKQ1.WW_Phone-17.2018.2007.428-20200903
Rooted or not: not
Frequency of Occurrence: Always
Dear Asus
After android 10 update, I have issue with the sound output of the device. Loudspeaker output is ok but 3.5 mm, BT Headset & USB audio output is so cheap that there is no bass android the audio quality is very bad. And earpiece volume is too low.
Urgent need of solution.
Thanks.
