Maybe they are not working on Android 10 for Asus max pro m1 as of these days and have put pause rn
milantailor254
Not working right now for Android 10 maybe as these shows.
6 REPLIES 6
BlueHunt
Zen Master I
milantailor254
I think its better for us now to stop speculating unnecessary things.. let it come when it would come..
milantailor254
Sanju
https://zentalk.asus.com/en/discussion/27365/maybe-they-are-not-working-on-android-10-for-asus-max-p...
Yess I expect the same
DarkSide
Sanju
Sanju i have tried battery calibration 2 times as suggested by you on other forum about "slow charging in max pro m2" but still my phone takes minimum 5-6 hour for a full 100% charge!!!. Can you plz help me?
nidhin3
Zen Master I
DarkSide
https://zentalk.asus.com/en/discussion/comment/76100#Comment_76100
1. Check your charger. Just remove the Cable from the brick and check if there is any dust. Just give a small blow of air with your mouth without letting water in. Also, check USB port and charging pin for any dust particles. (I had this issue and when I did this the problem got fixed) Also make sure that USB cable is properly inserted into the power brick.
2. Check with another good charger and see if issue still persists.
