12-28-2020 08:17 AM - last edited on 01-16-2024 04:18 PM by ZenBot
12-28-2020 09:00 AM
raushanpandit718It depends on the exact scenario of issue you are facing.I am using MPM1 with latest beta 5 V.438 and I am facing battery draining in my device any body have any solution
Is factory reset is solution of battery draining?
12-28-2020 11:02 AM
12-28-2020 11:59 AM
qromodynmcYes your right , not only for our phone is old but this buggy software alsoI'm having bit excessive battery usage on my phone too. It's not that bad when sleeping, like %5 at night but when using it, battery drains quite fast, my screen time is around 8 to 9 hour average. I'm still not %100 sure if it's software issue though because my sot wasn't that great in pie either, maybe my battery is just getting old.
12-28-2020 08:10 PM
raushanpandit718Never Factory Data Hard Rest Is Solution For Battery Draining Issue. I Have 3 Other Devices Like Poco, Vivo, Mi But In There Software Update I Never Do Factory Data Hard Rest Then Also They Have Good Battery Backup After Update, I Never Found Issue In That. But In Asus Every Update First They Do Factory Data Hard Rest, Which Never Be A Proper Solution Of Battery Draining. This Issue Due To There SoftwareI am using MPM1 with latest beta 5 V.438 and I am facing battery draining in my device any body have any solution
