Can I directly update from 0.340 (android 8) to 0.82 (android 9) manually?
vishnusdz013
Model Name: Max pro M1
Firmware Version: 0.340 (android 8.1.0)
Rooted or not: No
Frequency of Occurrence:
Can I manually update directly from firmware version 0.340 (android 😎 to 0.82 (android 9). The OTA is showing update to version 0.053.
Screenshots attached.
13 REPLIES 13
veeharish2005
Zen Master I
vishnusdz013
https://zentalk.asus.com/en/discussion/comment/96365#Comment_96365
Will every update be like 1.5 gb. Then a lot of data will be required 🙄
Only the 053 update is 1.5 gb others are 100 to 200 mb.
veeharish2005
Zen Master I
vishnusdz013
But different firmwares like .061 & .063 are blamed by many users for problems like battery draining. I dont want that to happen 😒
The latest version is .082 and I don't have any battery drain issue.
vishnusdz013
veeharish2005
https://zentalk.asus.com/en/discussion/comment/96400#Comment_96400
thanks 😊
eswar_cae
vishnusdz013
https://zentalk.asus.com/en/discussion/comment/96408#Comment_96408
thanks 😊
Is it Version WW-16.2017.2005.092? I am also not updated since 1 year. My phone is still on 8.1.0
victor010
Zen Master III
Hi please find the below steps:
1. As you are on .340 currently which is based on Android 8.
2. Download this update for Android 9 Version WW-16.2017.1905.053 which you have in your system update.
3. Android 9 latest version is .082 currently which you can download manually after downloading the automatic system update.
