11-19-2020 12:54 AM
Solved! Go to Solution.
11-19-2020 07:16 AM
11-19-2020 08:29 PM
11-19-2020 08:46 PM
Shubham SharmaI'm also facing this issue my phone is 2 years oldMy battery not even lasting 1 hour with screen on or 3 hours with screen off
It has been after the 0.87 update
Will Asus fix this issue in the next update or we have to get a new smartphone of other brand
Is anyone else facing the same issue
My device has been 2.5 years old and still my battery backup was good until last 0.82 update
Battery draining issue
11-19-2020 09:54 PM
Shubham SharmaYeah that's true did u checked with SC if probably there can b a chance of bad battery & may need to replace that. I had replaced my battery & was working good with 3 days of battery in single charge, but when I updated it to. 87 my phone's battery is getting discharged overnight almost from 60% to 0% totally discharged, then I tried using in safe mode for a day nothing happened but in safe mode 15% discharged overnight, I'm now only charging till 60-80% & yes giving some relief of this discharged till now.https://zentalk.asus.com/en/discussion/comment/134088#Comment_134088
Yes I have followed all your steps but the issue is yet to be resolved
I guess the problem is in the asus 0.87 update
Can I know when asus will be rolling out next stable update or else I need to switch to a new phone since it's difficult to carry a smartphone which lasts only for 2 hours
11-21-2020 08:55 PM
AJ1If I change my battery . Then any problem to be able ?https://zentalk.asus.com/en/discussion/comment/134156#Comment_134156
Can u try the same charging till 80% may this can help for some time.
That's also true that there is some :bug: or some hardware / software issue on some devices where this discharging issue is still not resolved & sure that asus will not take a note & work on this as they only have 1 option for every issues. & that still they are not able to manage this.
Try to turn on Battery saver & check as in my device it is working opposite rather than saving battery it is getting discharged fastly.
