11-19-2020 12:54 AM
Solved! Go to Solution.
11-22-2020 07:41 AM
11-19-2020 01:05 AM
Shubham SharmaPl calibrate battery, stopping background apps, check in safe mode if same issue persists try factory reset. Check out when battery safer is turned ONMy battery not even lasting 1 hour with screen on or 3 hours with screen off
It has been after the 0.87 update
Will Asus fix this issue in the next update or we have to get a new smartphone of other brand
Is anyone else facing the same issue
My device has been 2.5 years old and still my battery backup was good until last 0.82 update
Battery draining issue
11-19-2020 03:47 AM
11-19-2020 06:31 AM
11-19-2020 07:10 AM
AJ1Yes I have followed all your steps but the issue is yet to be resolvedhttps://zentalk.asus.com/en/discussion/40441/battery-draining-issue
