Asus ZenFone Max Pro M1 - Battery not charging, LED blinks at start only, after full drain
tom_123
Model Name: Asus ZenFone Max Pro M1
Firmware Version: .063
Rooted or not: Not Rooted
Frequency of Occurrence: Occurring currently
Hello All,
Like few other folks on the forum, I too observed my idle battery drain had increased after the .061 and .063 updates.
In order to try out the battery calibration process, I allowed my phone to drain overnight.
But it seems it has drained more than it should have. Now it's not charging at all even after leaving it connected for hours, the charging indicator LED also doesnt turn on.
After connecting Asus Charger the red LED (notification light ) blinks for a sec, the screen with an empty battery comes up. It then shuts itself down, due to 0% charge.
If I leave the phone connected to charger, it seems the phone is constantly trying to start itself (you can see a flash on screen for half a sec duration after every 3 seconds, only visible in dark), drains itself in the attempt and shuts down. Hence there is no charge being accumulated for it to even turn on the LED or the battery charging screen.
Things I have tried
Left the phone connected to Asus charger for 24hrs+
Left it charging by pressing Power + Vol Down buttons for an hour, as I read it helped some other android phones. But in their case it started up within a minute. Holding the power button while charging, does bring up the screen with battery for a sec, after every 10 seconds. But it doesnt help with the charging.
Tried different chargers. If I use any other charger than Asus, like an Mi one, I dont get the first screen showing empty battery, but the flash is brighter. I fear it might damage the display, so didnt left it connected for longer.
After trying all this, I think the only option left is to take it to Asus Service Center, but since it's a lockdown here it would probably take another month for the center to open.
Appreciate any suggestions, in case anyone else had faced a similar issue.
Thanks.
24 REPLIES 24
rajeshdora54
Same problem here.. Why Asus Why???. We had a believe on u.. some time Charging some time not.. i have to press the cable in to charging slot heavily to getting charge.. even i tried other companies charger it is not blinked at all. Now I am helpless, as my town don't have ur Service center. Plz do something.
I haven't rooted.
After *****63 update means for android Q beta
ENTRAPAN
Ive already charge and check the battery the port board the mother board but still it didn't charge. Please help
ENTRAPAN
Max pro M1
4 ram/64 rom
It didn't charge at all
Saja
Saja
https://zentalk.asus.com/en/discussion/28411/asus-zenfone-max-pro-m1-battery-not-charging-led-blinks...
Exactly I have the same problem with all symptoms. I approached local cell phone shop ,he checked and told that battery is 83%. May be the mother board is damaged,better take it to service centre. I regretted why I bought Asus.. worst
Update: I took the dead phone to service centre an they told,mother board failure, 3 gb 32gb variant motherboard costs 6000 rupees... How pathetic... Worst Asus in both software side and hardware side.. now phone is really in dead condition and need to buy another phone. My wish, Asus will never be a successful company in India
thegeralt1000
Rising Star I
Saja
https://zentalk.asus.com/en/discussion/comment/100482#Comment_100482
I vote your words
