Asus ZenFone Max Pro M1 - Battery not charging, LED blinks at start only, after full drain
tom_123
Model Name: Asus ZenFone Max Pro M1
Firmware Version: .063
Rooted or not: Not Rooted
Frequency of Occurrence: Occurring currently
Hello All,
Like few other folks on the forum, I too observed my idle battery drain had increased after the .061 and .063 updates.
In order to try out the battery calibration process, I allowed my phone to drain overnight.
But it seems it has drained more than it should have. Now it's not charging at all even after leaving it connected for hours, the charging indicator LED also doesnt turn on.
After connecting Asus Charger the red LED (notification light ) blinks for a sec, the screen with an empty battery comes up. It then shuts itself down, due to 0% charge.
If I leave the phone connected to charger, it seems the phone is constantly trying to start itself (you can see a flash on screen for half a sec duration after every 3 seconds, only visible in dark), drains itself in the attempt and shuts down. Hence there is no charge being accumulated for it to even turn on the LED or the battery charging screen.
Things I have tried
Left the phone connected to Asus charger for 24hrs+
Left it charging by pressing Power + Vol Down buttons for an hour, as I read it helped some other android phones. But in their case it started up within a minute. Holding the power button while charging, does bring up the screen with battery for a sec, after every 10 seconds. But it doesnt help with the charging.
Tried different chargers. If I use any other charger than Asus, like an Mi one, I dont get the first screen showing empty battery, but the flash is brighter. I fear it might damage the display, so didnt left it connected for longer.
After trying all this, I think the only option left is to take it to Asus Service Center, but since it's a lockdown here it would probably take another month for the center to open.
Appreciate any suggestions, in case anyone else had faced a similar issue.
Thanks.
24 REPLIES 24
johanpibkarma
I have a problem i bought Asus Zenfone max pro 1 year ago worked so far fine , but suddenly my battery heated up and spontaneously i removed it but due to heated up my phone got melt an now i didn't got battery from anywhere any suggestion what should i do now i m having urgent personal data in my phone. And also no nearby service center from where i help out this issue. i deeply tucked into it.
tom_123
  1. Model Name: Asus ZenFone Max Pro M1
  2. Firmware Version: .063
  3. Rooted or not: Not Rooted
  4. Frequency of Occurrence: Occurring currently
Hello All,
Things I have tried
  • Left the phone connected to Asus charger for 24hrs+
  • Left it charging by pressing Power + Vol Down buttons for an hour, as I read it helped some other android phones. But in their case it started up within a minute. Holding the power button while charging, does bring up the screen with battery for a sec, after every 10 seconds. But it doesnt help with the charging.
  • Tried different chargers. If I use any other charger than Asus, like an Mi one, I dont get the first screen showing empty battery, but the flash is brighter. I fear it might damage the display, so didnt left it connected for longer.
Thanks.
Same problem here. Any solution yet?
abhaykrishnan02
Zen Master I
tom_123
I was able to go into fastboot mode on the phone, when I connected it to my laptop while pressing Power and Volume Up button, and releasing Power button as soon as empty battery sign came up.
On fastboot mode I could see the battery voltage at 4395 mV , which I guess is the full battery level.
If I connect to laptop pressing Power and Volume Down, it goes upto Asus logo and shuts down, no recovery mode.
Both of above dont work directly on battery.
I guess I am also facing the same issue below faced by other folks on the forum and since it occurred when my phone was empty the firmware is not able to judge the current battery capacity.
https://zentalk.asus.com/en/discussion/25346/asus-zenfone-max-pro-m2-stuck-on-asus-logo-suddenly
These are all speculations on my part, so if any expert could please guide on this.
Still under a lockdown, so cannot take the mobile to a service center.
Thanks.
I have max pro m2, 2 month before I updated my phone to April security patch,after that I'm facing low calling sound problem so i talked to asus customer care they told me to clear cache from recovery mode,
I switch off my phone and i was trying to go in recovery mode but my phone was not starting,again i tried to go to in recovery mode but i was failed
So i thought to restart my phone but my phone was not starting,even i had pressed power button for 30 sec but it was not starting,
So i connected my phone to charger and left it , after 40 min it started normally automatically
abhaykrishnan02
Zen Master I
tom_123
Thanks.
Wait for 2-3 days if u didn't find anything helpfull try to flash rom by your own
Try charging your mobile by keeping it switched off.
