07-07-2020
06:16 AM
- last edited on
01-16-2024
12:43 AM
by
ZenBot
09-11-2020 12:04 PM
09-11-2020 07:24 PM
mcmorenoiThere is a latest update with firmware version 16.2017.2009.087 released for this device, update to it and do battery calibration and check whether your issue solved or not.@Asus please let the community know if this battery issue is induced via software to kill the phones hoping that users would buy anoter ASUS phone. Otherwise revert the update revision level to the last one that worked fine.
This is making the phone (at least mine) useless. It discharges in 6 to 8 hours in stand-by mode.
Please take action and help your users. Thanks.
09-11-2020 10:44 PM
nithya.prince520% idle drain is too much. Latest FOTA update version 087 is out. Check if your issue may solve with it.Please tell us some basic information before asking for help:
- Model Name: Asus Zenfone Max Pro M1
- Firmware Version: WW_Phone-16.2017.2005.082-20200506
- Rooted or not: No
- Frequency of Occurrence: everyday
- APP Name & APP Version (If your issue relates to the app): No
My phone's battery is draining even when it is idle all the background battery consumption is restricted, wifi, bluetooth, location everything is off even though the battery is draining 20 % per hour. Have checked my third party apps everything is going fine. this is happening after the recent security patch update. Am getting frustated with this problem from more than 20 days. I need some solution for this as soon as possible.
Abnormal Battery drain
09-22-2020 06:23 AM
