Abnormal Battery drain
nithya_prince5
Model Name: Asus Zenfone Max Pro M1
Firmware Version: WW_Phone-16.2017.2005.082-20200506
Rooted or not: No
Frequency of Occurrence: everyday
APP Name & APP Version (If your issue relates to the app): No
My phone's battery is draining even when it is idle all the background battery consumption is restricted, wifi, bluetooth, location everything is off even though the battery is draining 20 % per hour. Have checked my third party apps everything is going fine. this is happening after the recent security patch update. Am getting frustated with this problem from more than 20 days. I need some solution for this as soon as possible.
8 REPLIES 8
sisosama99
Same here I am thinking about visiting service center. It has become a burden to carry a power bank everywhere I go. Asus please resolve this issue as soon as possible or else our trust of your phone is draining like my phone battery issue
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
nithya_prince5
Here am sharing the SOT After following the steps mentioned below
veeharish2005
Zen Master I
nithya.prince5
Do a battery calibration by doing the steps below
Discharge your phone fully until it turns itself off.
Turn it on again and let it turn itself off.
Plug your phone into a charger and, without turning it on, let it charge until the on-screen or LED indicator says 100 percent.
Unplug your charger.
Turn your phone on.
