09-06-2023 04:04 AM
Good evening! Hi Asus Team, I just updated to the latest version and it's good but unfortunately I found and experienced problems and didn't enjoy the feature that was presented, namely "hide gesture indicator" maybe no one has reported about this, even though there have been 2x updates since now but in this section there are still lag problems when swiping up recently on the home screen or in the application, for that I hope the dev can optimize this use and I hope you listen to my complaints. Thank you ASUS team.
09-06-2023 04:19 AM
Yeah idk why its not fixed, i think thats can be easy to fix
09-06-2023 06:28 AM
i hope so.
09-10-2023 03:12 AM
I have Zenfone 8 and Zenfone 9. On Zenfone 8 it works smoothly, but on Zenfone 9 the animation lags.
09-10-2023 12:18 PM
09-14-2023 02:17 AM - edited 09-14-2023 02:18 AM
Hey @Madmax999,
The R&D team couldn't recreate the issue.
However, could you please share a log file for the same?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb).
Please share the log file with me via PM.
