10-27-2023 03:24 AM
I'm curious to know how you all are maximizing battery life on your ZenFone 10. Are there any specific settings or apps you've found to be particularly effective? I'm always on the lookout for ways to get the most out of my device throughout the day.
10-27-2023 05:53 AM
Disable all Apps you arent needed like(Google Spy Store)......Turn off Bluetooth...NFC....Location....bluetooth print service....install "clean APPS" from https://f-droid.org/
10-30-2023 02:36 AM
ok thanks,
Through Mcdvoice homepage, customer or participant can give his honest opinion (positive or negative feedback) to improve product quality, service, store quality & norms.
