zenfone8 battery
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-08-2022 01:05 AM
hi my zenfone 8 battery drain so fast, i am light user, no gaming. only using instagram,whatsapp and shopping app, can anyone help me for settings. for battery saver,....
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-08-2022 02:45 AM
do you use wifi or mobile data?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2022 01:56 AM
Hi @cattycat53
1.What's your current firmware version?
2.Did you notice a battery drain after recent updates?
3.You can try the following:
Charge your device to 100% before going to bed -> Put your device in flight mode and note the time -> Check the battery level in the morning and note the time again.
Report back with your results.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2022 04:09 AM
cattycat53Same here on Android 12. Battery is draining fast. Using dinamic setting and automatic refresh rate.hi my zenfone 8 battery drain so fast, i am light user, no gaming. only using instagram,whatsapp and shopping app, can anyone help me for settings. for battery saver,....
zenfone8 battery
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-14-2022 05:41 PM
I'm experiencing similar problems but for Android 11. I'll never go back to Android 12, it absolutely murdered the battery of my Pixel 4a and I had to downgrade. I'm surprised to see issues on the Zenfone 8 with Android 11 though. It's only happening for me while the screen is active. The battery life is decent while the phone is idle / screen is off.
