Proximity sensor problem during conversation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-23-2022 11:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-07-2022 05:50 AM
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-07-2022 08:59 AM
Mattias_ASUSPerhaps when you've sorted this for the Zenfone 8 you can also sort it for the Zenfone 9......its pathetic that this should be happening in both a previous model and now in the latest Zenfone 9. Oh and by the way this thread was started on May 23rd and its still going on 😡The issue will not disappear only by saying it exists, we are actively working on this and at this moment we need logs from users with the issue and to log the activity when it's happening, remember, the more logs and info the faster it will be to solve the issue, just like anything else.
2. Enter “.19595+=”
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-17-2022 04:23 PM
Maybe there is a way to toggle notifications off before making a call to test this theory?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-18-2022 08:54 AM
nicholasgibbsi think you are right. in my experience it happens alot when i get a notification during the call! i also posted it somewhere but i'm not sure if the developers paid attention to this.I am wondering if the problem has something to do with notifications? Sometimes I get the issue immediately and other times I am on the call for a little while before the screen wakes up while my face is next to the phone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-20-2022 06:11 AM
