My battery began to discharge quickly, I went into the battery settings in the "Battery consumption" parameters, and noticed that the following items consume a lot:
Standby - up to 18%
Other - 20%+
5 days ago I did a device reset via recovery!
Then I set up the smartphone again and installed the applications I needed.
For three days there were no problems with the charge at all!
And now I noticed that the above parameters began to drain the battery again ...
Why does this happen, and how to more specifically understand what exactly is the cause of the rapid discharge of the battery?
Firmware version WW/EU/RU_31.1010.0411.122
A test using a calculator (,12345+=) shows that everything is fine with the battery.
