How to find out what is draining the battery?
D_IMAN
Rising Star I
My battery began to discharge quickly, I went into the battery settings in the "Battery consumption" parameters, and noticed that the following items consume a lot:
Standby - up to 18%
Other - 20%+
5 days ago I did a device reset via recovery!
Then I set up the smartphone again and installed the applications I needed.
For three days there were no problems with the charge at all!
And now I noticed that the above parameters began to drain the battery again ...
Why does this happen, and how to more specifically understand what exactly is the cause of the rapid discharge of the battery?
Firmware version WW/EU/RU_31.1010.0411.122
A test using a calculator (,12345+=) shows that everything is fine with the battery.
10 REPLIES 10
willjoe2442
Find the Battery Screen
Click the Settings option from the Start menu.
In Settings, select System, and then select Battery.
Click See which apps are affecting your battery life to see more details.
Regards,
Will
D_IMAN
Rising Star I
willjoe2442
Regards,
Will
Reread the first post carefully, it says which applications consume the most energy!
Ronzky321
willjoe2442
Regards,
Will
C'mon Will. It's a Smartphone, not Windows.
keren_ASUS
@D_IMAN
Hi there, thank you so much for reaching out. Can you take a screenshot of the battery consumption?
