Cell Standby battery drain
Salvatore
i'm experiencing seriuos issue about battery, it's being constantly drained by cell standby with abnormal values. It's actually draining more than the display, that's unacceptable.
Can you please provide a fix/solution ?
Zenfone 8 - hardware and software details attached.
123 REPLIES 123
Salvatore
Elmir
https://zentalk.asus.com/en/discussion/comment/184051#Comment_184051
Stop using advanced mode and use either durable or dynamic, that fixed the crazy drain for me
Being using dynamic mode only since day one and always had the issue.
cicagorio
Rising Star II
Salvatore
https://zentalk.asus.com/en/discussion/comment/184101#Comment_184101
Did you try turning off adaptive battery and background app management?
madizon5
Change wifi from 5GHz to 2.4GHz had only a little effect. At 20:00 battery 100% and at 5:00 battery on 88%. I will try change mode from advanced to durable.
I hope that the Asus will solve this issue because it is terrible 😞 It is really poor battery management....
Salvatore
Elmir
https://zentalk.asus.com/en/discussion/comment/184133#Comment_184133
No, they are both on. I think that's the default setting.
cicagorio
Rising Star II
Salvatore
https://zentalk.asus.com/en/discussion/comment/184173#Comment_184173
It is, but try turning them off and seeing what happens.
