06-13-2021 02:21 AM
06-23-2021 01:57 AM
SalvatoreHiLatest updates.
I confirm that "scheduled power saving" was the cause of night-time cell standby battery drops. After disabling it the average drain during night was basically the same as the day-time. It is even more frustrating considering that feature was supposed to save battery, not the opposite. But meh, at least i've found the bug :
Still remains the issue about 4G network which keeps draining in standby almost double than 2G/3G. Didn't try 5G because my provider doesn't support it but i'm afraid it would be supreme disaster considering what's actually happening with 4G.
@ Asus Folks: any chances to have the 4G issue fixed by the next minor update ?
07-08-2021 10:09 AM
07-08-2021 10:23 AM
ElmirSome more context would be good. Thank you!I just compared my zenfone 8 mobile network standby drain (2g/3g/4g) with my 2 years old pixel 3.
Zenfone has 12.3% drain and pixel has 2%. Both are on the same location so they have the same cell signal quality. I would love to see some improvements here if possible.
07-08-2021 10:33 AM
CH_ASUSSo both phones connected to the same network, with 2g/3g/4g enabled, for most of the time both were connected to the same WiFi. Both in the same location the whole day (carried them together). 5g was disabled on zenfone 8. Only 1 sim card inserted, same as in pixel 3.https://zentalk.asus.com/en/discussion/comment/175660#Comment_175660
07-08-2021 10:47 AM
ElmirThanks!https://zentalk.asus.com/en/discussion/comment/175664#Comment_175664
At the end of the day on my Pixel 3 there was 2% drain in battery stats under "mobile network standby" and on my zenfone 8 there was 12.3% drain for "mobile network standby". Location Germany - mobile network Vodafone.
I would be glad to provide more info, or do some tests if you can tell me what information you are interested in and what would help you?
