Cell Standby battery drain
Salvatore
i'm experiencing seriuos issue about battery, it's being constantly drained by cell standby with abnormal values. It's actually draining more than the display, that's unacceptable.
Can you please provide a fix/solution ?
Zenfone 8 - hardware and software details attached.
123 REPLIES 123
andriej72
Czy to jest normalny pobór prądu z baterii ? W telefonie został włączony tryb nocny.
krypton
The mAh value depends on the voltage. 3545 mAh were measured at around 5V USB charging voltage but the battery voltage is presumably around 3.8V.
3545 mAh@5V are 4664 mAh@3.8V
If we estimate a charging efficiency of 85% we get: 4664 mAh x 0.85 -> 3964 mAh capacity
daniel91m
Rising Star II
andriej72
what type of telephone network signal and wifi type? (standard or 5GHz?)
andriej72
I have dual band wifi enabled. 4G + cellular network.
madizon5
Hi Guys,
Do you solve someone this problem with battery? I have the same problem.
at 20:00 - 100% battery
at 5:00 - 84% battery.
Advanced battery mode - everything on minimum or disabled.
Any ideas for solutions?
