Bad network signal level
Andre88
Hi everyone
I bought my ZenFone 8, 3 days ago.
I updated it at the last software and firmware version (android 12)
The connection level is extremely bad.
Where I was able to receive signal with my old and cheap Huawei now i struggle a lot even to see a video on Instagram
The connection jumps from 4G, 4G+, H+, 4G++
And in the same position the connection level is always extremely low
Are you aware of this issue?
I tried everything. Reset the APN, reset network preferences, restore the phone but nothing works
This is for sure a software issue because the antenna seems to work
Is it the same issue that almost all the smartphone are suffering after the upload to Android 12? (all the Samsung has the same issue)
Are you trying to fix it?
Is possible to downgrade the software to Android 11 and see if it shall work?
Thanks a lot
6 REPLIES 6
Chris1
Rising Star II
I see no difference between the ZF8 and a A42 5G or a Fairphone 4.
Andre88
Hi
I have a old Huawei p20 lite and it my ZenFone 8 isalways 20 dBm lover than the Huawei.
Instagram stories stopped always
Incredible for a phone of this level
martinparker28
Rising Star II
Andre88
Hi
Based on your reply then the Asus has a better signal strength, the lower the dBm the better signal??
Andre88
No, maybe I explain bad but it was 20 dBm worse
other key point for me is that it change always type of connection e connection level
it drained my battery
