Bad network signal level
Andre88
Hi everyone
I bought my ZenFone 8, 3 days ago.
I updated it at the last software and firmware version (android 12)
The connection level is extremely bad.
Where I was able to receive signal with my old and cheap Huawei now i struggle a lot even to see a video on Instagram
The connection jumps from 4G, 4G+, H+, 4G++
And in the same position the connection level is always extremely low
Are you aware of this issue?
I tried everything. Reset the APN, reset network preferences, restore the phone but nothing works
This is for sure a software issue because the antenna seems to work
Is it the same issue that almost all the smartphone are suffering after the upload to Android 12? (all the Samsung has the same issue)
Are you trying to fix it?
Is possible to downgrade the software to Android 11 and see if it shall work?
Thanks a lot
6 REPLIES 6
Mattias_ASUS
Hello!
Does your phone has the latest firmware update? Let me know if the issue has been solved with the newer updates.
ASUS_Bot
Rising Star II
