WIFI and Hotspot stop working!! Help please.
LuBuuuH
After some system updates, including android 13, my wifi worked normally, however at one point I needed to restart the phone, after I restarted it it never connected to WI-FI again I tried to restart a few times to see if the bug exit, but it didn't work.
Please, is there already a concrete solution to this problem? I saw that many people are reporting and I feel that Asus is not giving the necessary support.
5 REPLIES 5
Falcon_ASUS
@LuBuuuH
Are you currently experiencing issues where the Wi-Fi function cannot be turned on or off properly?
Please refer to the following FAQ for troubleshooting.
https://www.asus.com/support/FAQ/1006657/
If the problem persists, I have sent you a message, please check.
Well that was a big DUH  faq referral. Gee is my AccessPoint, router, switch, and or modem on?
   "well Gee I don't know - the other 23 devices I own all are connected and connecting as needed, but I just don't know...."
LuBuuuH
Yes, i the wifi button and also the hotspot button dosent enable, i have seen a lot of people with this problem...
DeltaLin
If you couldn't fix it,the worst case i know is the phone's wifi component is broken,888 can made the component around it overheat and destroy it.
