Front camera still using ultra wide angle lens in 3rd party apps on A11
CVonC
Rising Star II
I've just manually updated to the WW A11 firmware. I didn't have much hope in Asus giving us the option to use the main lens as the front camera in 3rd party apps considering that the beta testers never commented about it.
This phone was designed to give the best front camera quality. And while that is true for the stock camera app, why limit it to just that?
There are so many users that committed to purchasing this phone in the belief that they can use the main lens for social media and video conferencing apps. (Although deeper research would've lead to the same issue with the Zenfone 6).
Asus restricting it to use the cropped in ultra wide lens is even worse quality than the dedicated front cams of many other manufacturers. Even their lower tier phones have better quality front cams to be honest.
There is a way around it by flipping the rear camera over using the Flip toolbar. However, this of course leads to an upside down image. Which would be annoying to the recipient of a video call and also renders social media filters that detect faces useless unless you turn the phone upside down too (your view of your face will always be upside down).
So come on Asus, please just give us the option to default using the main lens and include a warning for high temperatures (like there is with 8k video recording) if you have to.
Make this phone truly the best selfie experience that you have marketed it to be!
14 REPLIES 14
aLc
Rising Star II
Plz make this available. It's very important especially for gcam.
CVonC
Rising Star II
aLc
You can change the camera ID in gcam so that it can use the main lens for the front cam. It's in the gcam thread on XDA forums.
carvalhojm2
cvonv
https://zentalk.asus.com/en/discussion/comment/163482#Comment_163482
In Android 11 this option is disabled, there is no way to change the ids because in Android 11 Asus blocked this option.
carvalhojm2
cvonv
as it will launch the zenfone 8, Asus is starting to block camera options on the zenfone 7, just for users to buy the zenfone 8
CVonC
Rising Star II
carvalhojm2
https://zentalk.asus.com/en/discussion/comment/163494#Comment_163494
Well in my gcam port which I've been using since A10, I have the option to use whichever lens I want for the front cam in A11 (I set the camera IDs manually since A10)
