Display problems and feature addition
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-08-2020
04:41 PM
- last edited on
01-16-2024
04:20 PM
by
ZenBot
The screen is also very blue for my taste, is there a way the night mode can be increased even further?
My last point is something my old OnePlus had, that you should really add. As you already have gesture control when the screen is off, it would be great if you could add an option to turn the flash light on and of with a gesture.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2020 11:30 PM
You can change the color temperature in the display settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-09-2020 03:21 AM
But yeah you're screen doesn't sound right at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-09-2020 06:05 AM
ZenNiniCould you maybe try to capture this behavior with another camera?Now after roughly a week with the new Zenfone I have realized a few problems with the screen and would like to know if I have faulty one. The brightness changes very abruptly when I change windows. For example if I am inside the settings menu, it changes its brightness constantly just by going from menu to menu. Can I turn this off or will there be a software update for it? (This happens with adaptive brightness on and off)
What screen setting are you using in splendid?
I can forward your suggestion regarding gesture for flashlight
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-10-2020 02:45 AM
