Display problems and feature addition
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-08-2020
04:41 PM
- last edited on
01-16-2024
04:20 PM
by
ZenBot
The screen is also very blue for my taste, is there a way the night mode can be increased even further?
My last point is something my old OnePlus had, that you should really add. As you already have gesture control when the screen is off, it would be great if you could add an option to turn the flash light on and of with a gesture.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-10-2020 08:28 AM
Anders_ASUSAfter @Tagion comment, I changed the Display frequency from auto to 90hz and that seemed to fix my issue. The color and brightness change is way more dramatic in low light, so therefore the video is somewhat dark.https://zentalk.asus.com/en/discussion/41446/display-problems-and-feature-addition
Could you maybe try to capture this behavior with another camera?
What screen setting are you using in splendid?
I can forward your suggestion regarding gesture for flashlight
Thanks!
My Splendid setting is Cinematic, as that seemed to give the warmest result. For most people the "night mode" strength is probably enough, I just wish I could make it even stronger. As the Zenfone doesn´t use a kCal Kernel, so rooting would not really solve the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-16-2020 08:02 AM
ZenNiniok, now I understand. I will feedback that the AUTO Hz option is switching frequency inside system settings. It shouldn't do that. Thanks!https://zentalk.asus.com/en/discussion/comment/138593#Comment_138593
https://us.v-cdn.net/6031231/uploads/BA3NK5GROFFR/vid-20201210-172338-1.mp4
- « Previous
- 1
- 2
- Next »
