06-15-2019
10:48 AM
- last edited on
01-16-2024
12:00 AM
by
ZenBot
06-17-2019 01:59 AM
06-30-2019 10:41 PM
07-03-2019 04:22 AM
Sounds like you have to return it to the store and get a new one. If you haven't alreadyHello! I had the same issue, the phone was stuck in a boot loop! I tried all the knew options such as power plus volume down or volume up etc. and now it doesn't even launch because the phone is not charging at all! Sometimes by holding power and volume down it shows a red led light and the flash logo on the screen but no percentage on charging at all and after 1 minute or so it shuts down! If I let it to charge the phone gets warm only! And all this happened after 4 days of use only! Please help ?
07-12-2019 06:40 AM
What kind of reply is that, is that that easy, come on, Best reply from manufacturers, just return right ???.Anders_ASUS said:zeu_sylverx said:Sounds like you have to return it to the store and get a new one. If you haven't alreadyHello! I had the same issue, the phone was stuck in a boot loop! I tried all the knew options such as power plus volume down or volume up etc. and now it doesn't even launch because the phone is not charging at all! Sometimes by holding power and volume down it shows a red led light and the flash logo on the screen but no percentage on charging at all and after 1 minute or so it shuts down! If I let it to charge the phone gets warm only! And all this happened after 4 days of use only! Please help ?
