07-14-2019 05:49 AM
08-19-2019 02:30 AM
I know it sounds stupid but try to re-enroll your fingerprints.andrea.coden said:I've got the same problem: my fp sensor is not responsive at all. Sometimes i need to put finger 3/4 times before it works. Any solution?
08-19-2019 02:48 AM
Just done. Seems to work. Hope it last.ColorSage said:I know it sounds stupid but try to re-enroll your fingerprints.andrea.coden said:I've got the same problem: my fp sensor is not responsive at all. Sometimes i need to put finger 3/4 times before it works. Any solution?
08-19-2019 04:00 AM
08-19-2019 03:30 PM
It should. The way you enroll is crucial. You are supposed to tap in different angles and finger positions. Only then sensor can recognise it under most circumstances.Cod The Doc said:Just done. Seems to work. Hope it last.ColorSage said:I know it sounds stupid but try to re-enroll your fingerprints.andrea.coden said:I've got the same problem: my fp sensor is not responsive at all. Sometimes i need to put finger 3/4 times before it works. Any solution?
