Fingerprint unresponsive
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-14-2019 05:49 AM
I have been using finger print without issues so far, but suddenly today morning the phone did not wakeup with fingerprint. It is not that it does not recognize the finger, there was no vibration (to indicate unmatched entry), so it was not active at all. It was as if fp is never enabled. I clicked power button, entered pin and thereafter finger print started working after turning off display. It has happenned only once so far.
Has anyone faced this? Is it an issue with fp sensor (temporarily not responsive) or expected behaviour, like it is in honor devices where pin is forced once every 3 days?
The phone is amazing in all other aspects, and moderators are responsive here, thank you Asus!
Thanks.
Thanks.
13 REPLIES 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-22-2019 03:29 PM
It happens to me when phone is plugged in charge. When i take it to unlock with fp, it doesn't work. I have to do my pin.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-01-2019 01:29 AM
Does this happen every time you charge or just sometimes? If it's just some times, then it's likely that the period has expired when its accepted to only use fingerprint to unlock. This is standard Android security measure. you have to unlock with pin every now and thenGentleman@roro said:It happens to me when phone is plugged in charge. When i take it to unlock with fp, it doesn't work. I have to do my pin.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-01-2019 01:59 PM
Let me tell you what the real issue is. After the latest FOTA, Zenfone 6 has started crashing. Your phone crashed and restarted overnight. That's why this happened.Vignesh said:I have been using finger print without issues so far, but suddenly today morning the phone did not wakeup with fingerprint. It is not that it does not recognize the finger, there was no vibration (to indicate unmatched entry), so it was not active at all. It was as if fp is never enabled. I clicked power button, entered pin and thereafter finger print started working after turning off display. It has happenned only once so far.
Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2019 03:15 PM
I don't think this is the case at all. That has only affected a very small amount of units. What Vignesh describes sounds like normal Android behavior. It will act like this on any Android phone.kinguntas23 said:Let me tell you what the real issue is. After the latest FOTA, Zenfone 6 has started crashing. Your phone crashed and restarted overnight. That's why this happened.Vignesh said:I have been using finger print without issues so far, but suddenly today morning the phone did not wakeup with fingerprint. It is not that it does not recognize the finger, there was no vibration (to indicate unmatched entry), so it was not active at all. It was as if fp is never enabled. I clicked power button, entered pin and thereafter finger print started working after turning off display. It has happenned only once so far.
Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-19-2019 02:24 AM
I've got the same problem: my fp sensor is not responsive at all. Sometimes i need to put finger 3/4 times before it works. Any solution?
