Better battery care suggestions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-28-2019 04:27 AM
Picked this phone because of the massive battery. Loved to see battery caring features from ASUS ❤️ . Please, if possible, add a possibility to set a threshold to charging (i.e stop charging after 80% or something, feature only seen in industrial laptops) and allow disabling of Quick Charge to make the phone last longer. You are only a few sysfs commands away from a durable battery. This phone is clearly built to last, as seen from the LCD display, the camera that can be pulled out manually unlike popup ones (don't do that unless after like 3yrs and motor is broken) and the collab with rhinoshield. Peek at AccuBattery if in doubt on how to make the battery last long. Don't want people voiding their warranty because they miss a battery-life-lengthening feature that, unlike other manufacturers, that can be implemented by ASUS, a company willing to listen.
Sorry for confusing English
14 REPLIES 14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-28-2019 06:18 AM
I've given exactly the same feature requests (basically making battery charge limit app out of it) but I'm not sure whether they'll ever implement it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-28-2019 06:47 AM
I used to run a superuser script to set /sys/class/power_supply/battery/battery_charging_enabled to 0 when above 80%. Why use a script when first-party apps can do it. I think whether ASUS implements this determines the mindset of it, to get more phone sales and earn more money / to serve existing users better and gain brand reputation. After all, this is only company standing with LCD displays that don't burn-in.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-28-2019 06:55 AM
In fact, to make development easier and faster, I give out some possible commands that can be used.
Depends on phone, this is for SD625, not sure if Zenfone 6 (SD855) have this
Quick Charge settings: /sys/class/power_supply/battery/allow_hvdcp3
Charging toggle:
Max temp of battery before bms disable charging:
/sys/class/power_supply/bms/temp_warm
Charging toggle:
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-28-2019 07:30 AM
I was using ai charge and battery stopped charging at 81..i set the time from 5am to 12am... Try fiddling with it
Haven't figured it out completely yet though.
