07-07-2019 05:09 AM - last edited on 01-16-2024 12:00 AM by ZenBot
07-23-2019 12:41 AM
how can i manually flash the full rom downloaded from asus site size 1.8gbkikoly said:Please update the firmware to 16.1220.1906.167mihaiambrono 說:Hi,
Any updates on this one?
Thanks,
Alex
07-23-2019 01:08 AM
Thanks,
Alex
07-23-2019 01:47 AM
i have the downloaded file but how can i install it? how can i flash itkikoly said:how can i manually flash the full rom downloaded from asus site size 1.8gbkikoly said:Please update the firmware to 16.1220.1906.167mihaiambrono 說:Hi,
Thanks,
AlexBIOS & FIRMWARE
https://www.asus.com/Phone/ZenFone-6-ZS630KL/HelpDesk_BIOS/
Version WW-16.1220.1906.167
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS630KL/UL-ASUS_I01WD-ASUS-16.1220.1906.167-1.1.1-user.zi...
07-23-2019 02:30 AM
mak.mahesh786 said:i have the downloaded file but how can i install it? how can i flash itkikoly said:how can i manually flash the full rom downloaded from asus site size 1.8gbkikoly said:Please update the firmware to 16.1220.1906.167mihaiambrono 說:Hi,
Thanks,
AlexBIOS & FIRMWARE
07-23-2019 02:36 AM
Not a technical guru, but i've managed to update the software via FOTA a few moments ago and currently when going to see info about software this is what is showing. I believe that this is what is required in order to fix the overheating of battery during charging. I am now trying to drain may battery to 15% and do a recharge for testing. Will come back with updates.kikoly said:mak.mahesh786 said:i have the downloaded file but how can i install it? how can i flash itkikoly said:how can i manually flash the full rom downloaded from asus site size 1.8gbkikoly said:Please update the firmware to 16.1220.1906.167mihaiambrono 說:Hi,
Thanks,
AlexBIOS & FIRMWARE
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS630KL/UL-ASUS_I01WD-ASUS-16.1220.1906.167-1.1.1-user.zi...Do not unzip the .zip file and place it directly in the root directory of your phone. Then reboot.Can't you update firmware via FOTA?
