battery overheat warning when charging
mak_mahesh786
Rising Star I
i recently manually updated my asus 6z, and now whenever i plug my charger, after sometimes it shows me that battery is overheating and the charging is stopped temporarily. is anyone facing same problem?
31 REPLIES 31
daveamol
I'm seeing the same overheating issue which actually sets my phone in a constant restart loop making the phone unusable. I'm also not seeing any updates on my device.
mak_mahesh786
Rising Star I
kikoly said:
kikoly said:
kikoly said:
Any updates on this one?
Thanks,
Alex
Please update the firmware to 16.1220.1906.167
how can i manually flash the full rom downloaded from asus site size 1.8gb
BIOS & FIRMWARE
https://www.asus.com/Phone/ZenFone-6-ZS630KL/HelpDesk_BIOS/
Version WW-16.1220.1906.167
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS630KL/UL-ASUS_I01WD-ASUS-16.1220.1906.167-1.1.1-user.zi...
i have the downloaded file but how can i install it? how can i flash it
Do not unzip the .zip file and place it directly in the root directory of your phone. Then reboot.
Can't you update firmware via FOTA?
i want to do a fresh clean install of the full firmware
kikoly
Hall of Fame II
kikoly said:
kikoly said:
kikoly said:
Thanks,
Alex
BIOS & FIRMWARE
If you put .zip in the root directory and restart the phone, you can't update it. Use the following method to manually update the firmware.
kikoly
Hall of Fame II
If the phone is in an infinite restart cycle, it is recommended to check to the service center.
If you are unable to update via FOTA, you can download the update file manually.
mihaiambrono
Just recharged the phone after the update of firmware and can confirm that this issue is now fixed.
Thank you all for all your help and support! 🙂
