[Zenfone5 ZE620KL] Location (gps) error while hotspot mode on
adii_nugroho
Model Name: ZE620KL
Firmware Version: WW_16.0615.2005.130
Rooted or not: no
Frequency of Occurrence: always
APP Name & APP Version (If your issue relates to the app): GPS and Hotspot
hi Asus,
after upgrade to the latest firmware [200420] ZenFone 5 ZE620KL_WW_16.0615.2020.126 i have a problem while using gps on my Zenfone 5 with sharing hotspot mode on. location seem can not be found, it is like can not conect to gps hardware. after turn off hotspot, the gps location back to normal. no problem in previous firmware version. pls help.
just upgraded to ZE620KL_WW_16.0615.2005.130 and the problem still there.
my previous question with screen capture and video can be found here
adii.nugroho
  1. Model Name: ZE620KL
  2. Firmware Version: WW_16.0615.2020.126
  3. Rooted or not: No
  4. Frequency of Occurrence: everytime turn on hotspot
  5. APP Name & APP Version (If your issue relates to the app): Location & Hotspot
hi Asus,
after upgrade to the latest firmware [200420] ZenFone 5 ZE620KL_WW_16.0615.2020.126 i have a problem while using gps on my Zenfone 5 with sharing hotspot is on. location seem can not be found, it is like can not conect to gps hardware. after turn of hotspot, the gps location back to normal. no problem in previous firmware version. pls help.
thanks
Location (gps) error while hotspot on
thanks in advance
1 ACCEPTED SOLUTION
Accepted Solutions
Christine_ASUS
Community Legend II
Hi adii.nugroho
The issue of gps error while hotspot mode on has been solved with the latest version V16.0615.2006.131, which is now on our official website, please check your phone Settings>System>System update, or visit our website for manual update
https://www.asus.com/Phone/ZenFone-5-ZE620KL/HelpDesk_BIOS/
#Update Guide
https://www.asus.com/support/FAQ/1009748/
5 REPLIES 5
Christine_ASUS
Community Legend II
Hi adii.nugroho
Thank you for your asking. Kindly provide the information below so that we could better assist you.
1. To check SMMI test
Calculator> type ".12345+=">SMMI TEST>Single Test>Wi-Fi Test/SIM Signal Test
2. Could GPS and Hot spot work at the same time in "Safe Mode"?
If it works, please check on any disturbance from the installed 3rd party Apps.
3. Also, please try "the Factory Reset"
Settings>System>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
4. If the situation remian the same, please provide me the video by the following steps below
Using google map/gojek>Open hotspot>Using google map/gojek>Close hotspot>Using google map/gojek
adii_nugroho
Christine_ASUS
Hi adii.nugroho
hi @Christine_ASUS
this is information that may help,
1. SMMI Test, result WI-FI Test :heavy_check_mark: OK ; SIM Signal :heavy_check_mark: OK
2. in Safe Mode, problem is still there, GPS will still popping up notification like location is not 'set on' yet.
3. still hoping that this bug can be solved by patches. because this problem coming from ZE620KL_WW_16.0615.2020.126, fyi.
4. attached new video may can help you
thank you
Christine_ASUS
Community Legend II
Hi adii.nugroho
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Christine_ASUS
Community Legend II
Hi adii.nugroho
#Update Guide
