#Bugs in Asus Zenfone Max Pro M1:438
sujanjsr0
Rising Star II
To much battery drain in idel mode.
Almost 28% of my battery is drained overnight.(in 7 hrs)
Mobile data was off, location was off hotspot was off .i mean everything was off.but i don't know who eat my 28% battery.1day ago there was only 2-3% of battery drain in letest pie update.
Please give me any solution
4 REPLIES 4
sujanjsr0
Rising Star II
Dekho ke bhag kyu rhe ho?Solution do bsdwalo 🥺
RadeonPS
Rising Star II
sujanjsr0
For me , everything was on ,yet during night idle drain was very low.
The flat curve is due to dose mode. For that to kick in, you need to charge your device above 80% for some odd reason.
And then use it. Charging till 40 and then keep it idle overnight somehow drains it if the device was in continuous use and the play services, system are exempted from battery optimisation. Charging to 80 and above resets these services and the RAM usage of system drops down 200-300MB.
Christine_ASUS
Community Legend II
Hi sujanjsr0
1. If the "Fingerprint" is turn off, does the situation remain the same?
Settings>Security>Fingerprint
2. Enter "Safe Mode" and leave a 100%-charged phone in sleep(idle) mode in a night, then provide me the screenshot of
①Setting>Battery
②Setting>Battery>3 dots on the top"Show app usage"
If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
3. If the issue remains the same in "Safe Mode", please try "the Factory Reset"
Settings>System>Reset options>Factory data reset
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
4. Is there any zone heating up while using/idling? How long has the battery been used?
For more information, please refer to the links below
https://www.asus.com/support/FAQ/1009546/
https://www.asus.com/support/FAQ/1009547/
ASUS_Bot
Rising Star II
