Idle mode Battery drain when phone is in standby(sleep) mode.
Aditya_Singh
Model: Zenfone Max pro m1
Version: .087
Status: Not Rooted
I don't know my other max pro m1 friends are still getting this issue or not..
I can't understand why the battery drains in idle mode, though I haven't turned on location, hotspot or wifi and even no apps are running in background... Sometimes I see no drain at all coz after 6-7 hrs of no usage just 1% drop , But sometimes almost 2% drop per hour and 8-10% drop when i sleep..and sometimes 15-20% drop when I sleep (usually i sleep 5-6hrs)
I am satisfied with my Screen On Time (SOT).. Usually it gives 10-12hrs on normal usage or little bit gaming and charges im around 2hrs 40min..
I don't know from how long this battery drain problem is going on as my phone battery was swollen 6 months ago and I replaced it..From then i started noticing my battery stats and I saw this problem...I think this problem has started 6-7 months ago and still not resolved...
Every time when i get a system update I think this problem would be solved but there is Only a change in pattern of the battery drain after every update but no solution at all... Please help me with my problem if anyone can...!
Thanks and regards..
4 REPLIES 4
AJ1
Rising Star II
Aditya Singh
Version: .087
Status: Not Rooted
Pl check for any 3rd party app causing it, calibrating battery, if not worked check in safe mode. Full charge the battery to 100%,turn on safe mode & leave it overnight & post the SS.
Aditya_Singh
AJ1
https://zentalk.asus.com/en/discussion/40694/idle-mode-battery-drain-when-phone-is-in-standby-sleep-...
I have already tried battery calliberation, it doesn't works...
Also once I had tried in safe mode, I think that time drop was about 7-8%.. but probably that was in .084 version..
As you said I will try once again in safe mode today and then post the ss ...
@Aditya Singh what is the total cost of battery replacement ? Kindly let me know ..
Aditya_Singh
mailme.sujoy660
Total cost was ₹1780....
