Idle mode Battery drain when phone is in standby(sleep) mode.
Model: Zenfone Max pro m1
Version: .087
Status: Not Rooted
I don't know my other max pro m1 friends are still getting this issue or not..
I can't understand why the battery drains in idle mode, though I haven't turned on location, hotspot or wifi and even no apps are running in background... Sometimes I see no drain at all coz after 6-7 hrs of no usage just 1% drop , But sometimes almost 2% drop per hour and 8-10% drop when i sleep..and sometimes 15-20% drop when I sleep (usually i sleep 5-6hrs)
I am satisfied with my Screen On Time (SOT).. Usually it gives 10-12hrs on normal usage or little bit gaming and charges im around 2hrs 40min..
I don't know from how long this battery drain problem is going on as my phone battery was swollen 6 months ago and I replaced it..From then i started noticing my battery stats and I saw this problem...I think this problem has started 6-7 months ago and still not resolved...
Every time when i get a system update I think this problem would be solved but there is Only a change in pattern of the battery drain after every update but no solution at all... Please help me with my problem if anyone can...!
Thanks and regards..
Comments
Pl check for any 3rd party app causing it, calibrating battery, if not worked check in safe mode. Full charge the battery to 100%,turn on safe mode & leave it overnight & post the SS.
I have already tried battery calliberation, it doesn't works...
Also once I had tried in safe mode, I think that time drop was about 7-8%.. but probably that was in .084 version..
As you said I will try once again in safe mode today and then post the ss ...
@Aditya Singh what is the total cost of battery replacement ? Kindly let me know ..
Total cost was ₹1780....
