ZenFone 5Z serious battery drain after .87 update
patelbabujio15
I am facing a serious battery draining issue after recent FOTA update
Please fix it ASAP 😓
8 REPLIES 8
AmitGarde
Community Legend II
patelbabujio15
After seeing your drain graph 23% for 2 hours is not alot drain but still dont worry, this battery drain issue in .87 is already in investigation and devs are working on it wait for future firmware update this will be fixed
Thanks!😊
victor010
Zen Master III
Hi there, please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
Debasish_Sahoo
Zen Master I
amitgarde3
https://zentalk.asus.com/en/discussion/32019/zenfone-5z-serious-battery-drain-after-87-update
Thanks!😊
He used only 1hr 21 mins and rest of the time he hasn't use his phone so according to 1hr 21mins 23% battery drain means battery drains a lot as compared to other firmware updates.
Debasish_Sahoo
Zen Master I
Now I talked with him and he said that he bought this phone 6-7 months ago so I don't thik that a new battery should discharge this much. So I think it's software related issue.
