My phone was low on battery, turned off and now keeps rebooting while charging.
Jeronimo
Info:
Model Name: Asus Zenfone 5 Selfie Pro
Firmware Version: Not sure but it's Android up to date (July 2020)
Rooted or not: no
Frequency of Occurrence: All the time while charging
I was using my Zenfone 5 selfie pro as usual when it suddenly turned off, it was low on battery but it was >5% so i wasn't expecting that to happen. Then when I connected my charger it showed the charging screen, then it turned off, then showed the charging screen, then turned off and so on... This keeps happening.
Also the LED that indicates if it's charging is off. I tried with other 2 chargers (which worked on other phones) and the same happened.
I have had this phone for about 2 years so maybe it could be that the battery has finally given up, but I would really appreciate some insight into what might be happening.
I would be thankful for any help you can give me, or your experience if you've had this same problem!
10 REPLIES 10
adityapruthi200
Rising Star II
Your flex cable connecting sub board to main board might be lossened up. Try fixing that.
cruz_jazon69
Jeronimo
Info:
  1. Model Name: Asus Zenfone 5 Selfie Pro
  2. Firmware Version: Not sure but it's Android up to date (July 2020)
  3. Rooted or not: no
  4. Frequency of Occurrence: All the time while charging
same problem
cruz_jazon69
adityapruthi2001
i got the same problem and i went to asus service center and they said it was battery problem and they want me to pay 60$. is it possible that your answer is my only solution to my phone prob?
adityapruthi200
Rising Star II
cruz.jazon69
https://zentalk.asus.com/en/discussion/comment/97611#Comment_97611
Yes, 90% probability..... Did your handset ever did fell??? Not imp if it fell that time..... I was driving and had an accident came home and phone wasn't charging.... (got to know after 6 hours) I opened my sealed back myself.... (2 year old phone)... And I saw that one of the Flex cables got unclipped from it's place..... Which was the flex connecting SB TO MB.... I knew it was done due to that shock my phone went during the crash accident. So yeah, I left the flex cable like that.... sealed back my phone as it is.... Took it to service centre they told my it will cost around ₹1000 (12$) (500 service charge +350 subboard+150 flex cables) 😂😂.... They said.... Your subboard as well as flex cables are damaged. 😂😂I laughed.... I denied... Said them pls return the phone without sealing it. They gave and I clipped the Flex cables back again.... And yeah... Its working smooth since then. 😂So that was my exp. Hope this will also help you. FYI.... MY PHONE WAS LIKE WHEN I PLUGGED IN CHARGER.... THE RED LED WOULD BE ON FOR 3 SEC... THEN GO AWAY... INDICATING THAT PHONE WAS GETTING POWER BUT BATTERY WASN'T CHARGING. SO IF THAT'S HAPPENING TO YOU. THEN HERE YOU HAVE IT.
PEACE.
