My phone was low on battery, turned off and now keeps rebooting while charging.
Info:
- Model Name: Asus Zenfone 5 Selfie Pro
- Firmware Version: Not sure but it's Android up to date (July 2020)
- Rooted or not: no
- Frequency of Occurrence: All the time while charging
- APP Name & APP Version (If your issue relates to the app):
I was using my Zenfone 5 selfie pro as usual when it suddenly turned off, it was low on battery but it was >5% so i wasn't expecting that to happen. Then when I connected my charger it showed the charging screen, then it turned off, then showed the charging screen, then turned off and so on... This keeps happening.
Also the LED that indicates if it's charging is off. I tried with other 2 chargers (which worked on other phones) and the same happened.
I have had this phone for about 2 years so maybe it could be that the battery has finally given up, but I would really appreciate some insight into what might be happening.
I would be thankful for any help you can give me, or your experience if you've had this same problem!
Comments
Your flex cable connecting sub board to main board might be lossened up. Try fixing that.
same problem
i got the same problem and i went to asus service center and they said it was battery problem and they want me to pay 60$. is it possible that your answer is my only solution to my phone prob?
Yes, 90% probability..... Did your handset ever did fell??? Not imp if it fell that time..... I was driving and had an accident came home and phone wasn't charging.... (got to know after 6 hours) I opened my sealed back myself.... (2 year old phone)... And I saw that one of the Flex cables got unclipped from it's place..... Which was the flex connecting SB TO MB.... I knew it was done due to that shock my phone went during the crash accident. So yeah, I left the flex cable like that.... sealed back my phone as it is.... Took it to service centre they told my it will cost around ₹1000 (12$) (500 service charge +350 subboard+150 flex cables) 😂😂.... They said.... Your subboard as well as flex cables are damaged. 😂😂I laughed.... I denied... Said them pls return the phone without sealing it. They gave and I clipped the Flex cables back again.... And yeah... Its working smooth since then. 😂So that was my exp. Hope this will also help you. FYI.... MY PHONE WAS LIKE WHEN I PLUGGED IN CHARGER.... THE RED LED WOULD BE ON FOR 3 SEC... THEN GO AWAY... INDICATING THAT PHONE WAS GETTING POWER BUT BATTERY WASN'T CHARGING. SO IF THAT'S HAPPENING TO YOU. THEN HERE YOU HAVE IT.
PEACE.
yes it did fell in stairs but that was a long time ago but my phone is like that when i charge it red led then a empty charging battery logo it vibrates and then go off and then it repeats, when i turn on it it will only show asus logo then vibrates then go off, but when i push the power button and volume up it will go stuck at fastboot mode and it wont shutdown until you press the power button again so i dont think that my battery is the problem, sorry for my english mate hope you understand it thankyou, how can i open my open to check the cable and how can i close it again
Hi cruz.jazon69
Thank you for your reply. Kindly try some stay-at-home troubleshooting tips below:
A. Update your firmware version to the latest version
B. Change adapter and cable
C. Please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key"
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Factory data reset"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/
Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
If the situation remain the same after the hardware reset, because your device once suffered a strong physical impact, please bring your device to the repair center and follow the diagnosis of the local engineer.
Ohhh! That's for sure not the Flex cables problem. For this.... I will suggest you to not follow any advices apart from moderators and go for a service centre to check the problem.
My phone not charge during on .
How to fix that ?
Hi cruzkemueljoseph
Thank you for your asking. Please try to clean the port with compressed air can first. Then follow the three steps I mentioned above. If the situation remain the same, kindly bring your device to the nearest repair center for device checking.
My phone cant enter recovery mode and i did the volume down + power button and nothing's happening it only show asus logo then vibrates then it will go shutdown, but when i press volume up + power button it will enter fastboot mode and it will stay like that as long as i wont press the power button to shut it down and the service center said that my battery was the problem and i need to pay 60$ and i need to wait atleast 1 month
