07-15-2020 11:49 PM
07-15-2020 11:58 PM
aspectlastaDid you try checking with diffrent chargers? If yes then whats the status does it charge?Please tell us some basic information before asking for help:
- Model Name: Asus 5z
- Firmware Version: WW_100.10.107.87_20200520
- Rooted or not:not
- Frequency of Occurrence: Persistent
- APP Name & APP Version (If your issue relates to the app):
My asus 5z is not charging. Some times when I cover proximity sensor it charges and stops after few minutes. Not sure why this is happening but it is not charging even when my phone is off. The proximity sensor trick doesn't work everytime. I restarted my phone several times but the problem persists. Please give a solution for this as I won't be able to use my phone with this condition.
Asus 5z not charging problem
07-16-2020 12:30 AM
07-16-2020 12:43 AM
aspectlastaThis is strange proximity has nothing to do with charging please see if safe mode behaves same on your 5z dont forget to turn your charging on after you entre in safe modeNo its not charging with other charger but as I said with the proximity sensor trick it sometimes charges.
07-16-2020 01:02 AM
