Battery issue
Model Name:zenfone 5z
Firmware Version:10
Rooted or not:not
Frequency of Occurrence:50
in this new update battery drained quickly in about 2 to 3 hours.
Please provide solutions.
4 REPLIES 4
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
6 . Check the following article for more information: https://www.asus.com/in/support/article/604/
It's show only 3 hour screen on time.
@victor2020 @ServiceC_ASUS and asus team no reply yet.
Gera
3 hrs? I Get 2:30 max. Normal is 4
