Battery drain Issue in recent update .87
Debasish_Sahoo
Zen Master I
Model Name: Asus 5z
Firmware Version: .87
Rooted or not: No
Battery drain issue again started after .87 update
12 REPLIES 12
victor010
Zen Master III
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
burakterzi91
Rising Star I
Debasish Sahoo
  1. Model Name: Asus 5z
  2. Firmware Version: .87
  3. Rooted or not: No
Same, look Instagram 😄
There is a problem with the latest version of the battery.
https://zentalk.asus.com/en/discussion/30477/5z-zs620kl-87-update-wrong-battery-usage#latest
Debasish_Sahoo
Zen Master I
victor2020
Hi sir,
I have tried everything but nothing worked!! This problem arises after updating to .87 firmware and this problem was not there in previous firmware.
I think this is a bug and everyone is facing this.
Thank you
Debasish_Sahoo
Zen Master I
@victor2020 u can see this,
I didn't use jio saavn but battery shows it consumed 4%, so clearly this is a bug as battery stats showing wrong information
