Battery drain Issue in recent update .87
Debasish_Sahoo
Zen Master I
Model Name: Asus 5z
Firmware Version: .87
Rooted or not: No
Battery drain issue again started after .87 update
12 REPLIES 12
Debasish_Sahoo
Zen Master I
Now you can see without any use jio saavn has consumed 10% battery
I am sure it is showing wrong information
Share your views on this @Anders_ASUS @victor2020 @CH_ASUS
BrunoF20
Zen Master I
BrunoF20
  1. Model Name: ZS620KL
  2. Firmware Version: .87
  3. Rooted or not: Non-rooted
  4. Frequency of Occurrence: Constantly
  5. APP Name & APP Version (If your issue relates to the app): System
  1. I felt battery percentage holds on a number for a while and then runs out quick suddenly after moderate or heavy use, instead real-time monitoring the charge as expected.
  2. It happens too when 100% charged, then - when unplugged - it drains the first 10% very quick.
  3. Now, I needed to restart the device with 5%, it just turned off, didn't try to turn on again and just shown the empty battery.
Could you take a look on the sensor settings?
It seems this is a recurrent bug of the Android 10 builds on 5Z.
Already tried:
  • Wipe data/Factory reset (nothing changed)
  • Other Android 10 builds (nothing changed)
  • Battery calibration (nothing changed)
  • Downgrade to 9 (but I can't stay there because of low wi-fi signal bug and security patches)
[5Z] Battery percentage not precise.
Did you feel it too?
Debasish_Sahoo
Zen Master I
BrunoF20
https://zentalk.asus.com/pt/discussion/30774/5z-battery-percentage-not-precise
Yes bro and I think everyone is facing this issue after .87 update
BrunoF20
Zen Master I
Debasish Sahoo
https://zentalk.asus.com/en/discussion/comment/91025#Comment_91025
Did you saw the post that I linked or thought I was talking about Instagram?
Just to be sure. 😄
Debasish_Sahoo
Zen Master I
Yes I saw your link
