Battery drain Issue in recent update .87
- Model Name: Asus 5z
- Firmware Version: .87
- Rooted or not: No
Battery drain issue again started after .87 update
Comments
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
Same, look Instagram :D
There is a problem with the latest version of the battery.
https://zentalk.asus.com/en/discussion/30477/5z-zs620kl-87-update-wrong-battery-usage#latest
Hi sir,
I have tried everything but nothing worked!! This problem arises after updating to .87 firmware and this problem was not there in previous firmware.
I think this is a bug and everyone is facing this.
Thank you
@victor2020 u can see this,
I didn't use jio saavn but battery shows it consumed 4%, so clearly this is a bug as battery stats showing wrong information
Now you can see without any use jio saavn has consumed 10% battery
I am sure it is showing wrong information
Share your views on this @Anders_ASUS @victor2020 @CH_ASUS
Did you feel it too?
Yes bro and I think everyone is facing this issue after .87 update
Did you saw the post that I linked or thought I was talking about Instagram?
Just to be sure. :D
Yes I saw your link
Btw the apps aren't really consuming that much battery
The stats are incorrect
I've noticed that the graph even shows some apps with battery consumption which I didn't even use
It's a just a bug in my opinion as I still get good battery life
Yes bro I agree with you.
There is no problem with the battery instead i am getting good sot also idle drain is very less . The only problem is battery stats and which is due to google security patch. Even my friend is also facing this on Oneplus too. Not a Asus problem at all.
