09-28-2020 03:23 AM
09-29-2020 11:57 PM
Victor01_ASUSOh please I've already factory reset my 5z several times and still the same problem occurs again and again. The only thing we 5z users want is a bug free android 10 update instead of a security patches.Hi, Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
you may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
09-29-2020 11:59 PM
amitgarde3Yep it's the same cpu spike after the September security update and the same problem occurs to me as you've mentionedhttps://zentalk.asus.com/en/discussion/36689/battery-drain-and-over-heating
Is it a cpu spike bug after september security patch? I observed this two time as soon as i updated phone latest .99 phone got heated alot and battery was drain faster than normal but dont know got normal again & after few days again same problem occured and again it is much normal now heating happens sometimes some other days not constantly@Anders_ASUS @Christine_ASUS @ARP_ASUS @Gustav_ASUS
09-30-2020 04:29 AM
09-30-2020 04:45 AM
Anders_ASUSI really appreciate if ASUS can fix this issue and also other bugs.A battery bug fix is coming in next FOTA. This fix applies for the battery issues which has earlier been reported. However, the more severe battery drain you just experienced was most probably due to the google play service bug which they just fixed. So if you have the latest update of google play, then you shouldn't have this battery drain any longer.
09-30-2020 04:51 AM
Anders_ASUSThanxx alot will check this 👍😊A battery bug fix is coming in next FOTA. This fix applies for the battery issues which has earlier been reported. However, the more severe battery drain you just experienced was most probably due to the google play service bug which they just fixed. So if you have the latest update of google play, then you shouldn't have this battery drain any longer.
