Zenbook will not wake up from sleep
Plaidshore
Model: Asus Zenbook Flip UX461UA
OS: Windows 11 Home (was happening with Windows 10 for ages though)
BIOS: 321
For the past year or more, I have intermittently been experiencing an issue with my Asus Zenbook where when it has gone to sleep it will not awaken without a hard reset (holding in the power button until the computer shuts down and then turning it back on). This is an issue that has been getting progressively worse - where initially it would happen 1 in 10 times when the laptop goes to sleep, now it is more like 8 in 10 times. To make matters worse, it has become progressively more likely that when this occurs the laptop will seemingly run indefinitely (but will still not turn on without a reset) and is extremely hot to the touch if it's plugged in (this sort of heat never happens when the laptop is on and in use), or will run until the battery dies entirely if it's not plugged in. If it's helpful for diagnosis when this occurs the power button blinks slowly (as long as the laptop has not died of course).
Looking through the forums here I see that I'm not the only one experiencing this issue, but since there seems to be no resolution (other than one person who believed they'd resolved their issue), I thought I would also explain my problem, and see if someone has any ideas.
Some things to note:
Initially I was under the impression that this happened exclusively when it was in charge mode when it went to sleep - I have since determined this was not the case. Either that or the problem has worsened, because it happens whether it is on charge, has been on charge and was then unplugged before sleep or has not been on charge during any of the time the laptop was awake.
As a caveat to my last point, it will ALMOST always happen if it is plugged in, but only happens most of the time when it's not.
There is no difference in manually putting it to sleep versus allowing it to fall asleep by closing it or leaving it open and letting it time itself out.
Things I have attempted to resolve it:
Before switching to Windows 11 I found the following discussion, and followed the steps therein with no change: https://zentalk.asus.com/en/discussion/46571/hopefully-finally-solved-the-sleep-never-wake-up-proble...
I read that it may be a Windows 10 issue, so when a free update was offered to change to Windows 11 I took it, and you guessed it, no change.
Based on another thread I updated the BIOS, and did all other steps besides the final step of resetting the system. I have read on other threads that this did not help, and I was hoping to hear from someone who did have that work before I went to the effort of a full system reset.
I'm very hopeful that someone can help me out. I'm in a position now where this is transitioned from an inconvenience to unusable. I love this laptop but I wouldn't even consider buying a newer version because most of the other people reporting this issue have newer versions of the zenbook than mine.
13 REPLIES 13
Plaidshore
Falcon_ASUS
https://zentalk.asus.com/en/discussion/61399/zenbook-will-not-wake-up-from-sleep
@Plaidshore
Failure to wake up normally is usually caused by a system error. I would recommend that you try restoring your system first.
https://www.asus.com/support/FAQ/1013064/
The comment below - disabling the Intel(R) Audio Displays in the device manager solved all the issues I was experiencing, and basically saved my laptop before I attempted a full reset. I would definitely recommend attempting this before trying a full reset.
ariimoana
I'm astonished that Asus and Intel are not able to solve this issue. I also disabled the Intel(R) Audio Displays and wake issues are now history. Don't know what would happen if I connect an HDMI screen to my laptop though 😞
ariimoana
To complement on my previous post, I updated my graphic driver from Intel last night, and waking from sleep freeze issue happened again.
I checked the device manager and Intel(R) Audio Displays was back after the update. So I guess the issue really is with this driver.
I tried opening a support ticket with Intel via my Intel Graphics configuration app. Hope it'll lead somewhere...
Mark_Trend
okna2003
Disable (without uninstalling) Intel(R) Audio for displays in Device Manager. After that, be sure to restart your laptop.
UX330UAR sleep - Page 2 — ZenTalk (asus.com)
Thank you okna2003!!! I was about to bin my UX461 because of the crashy sleep function. Instantly after applying this workaround sleep was working beautifully, and 1 week later continues to work. I had tried disabling modern sleep, disabling hybrid sleep, disabling virtualisation, disabling various startup services, updating to win11, updating graphics drivers from asus, updating bios, downgrading bios, full wipe+reinstall, but none of it worked. Disabling the "Intel(R) Display Audio" has worked! For some reason named differently in my device manager?
For anyone else having trouble finding "Intel(R) Audio Displays", these are the steps:
Start -> Device Manager -> Sound video and game controllers -> Intel(R) Display Audio -> (right click) -> Disable device
Restart the laptop.
Mark_Trend
I wonder if Windows Update replaced the official Asus graphics driver with the stock Intel graphics driver? Device Manager shows my UX461's Intel UHD 620 graphics is on version 30.0.101.1340 while the latest Asus official driver is V26.20.100.7325. My Intel(R) Display Audio driver is version 10.27.0.11.
I'm not sure Intel's suggested workaround is very practical since disabling Windows update is almost impossible now. From https://www.intel.com/content/www/us/en/support/articles/000059755/graphics.html :
Windows* auto-update may overwrite the official drivers and revert it back to Intel's drivers. In this case, you will need to re-install the official driver again. To avoid Windows update from overwriting the official driver, turn off automatic updates and do not select to update your graphic driver when available from Windows update.
