Zenbook ux325 battery short life
rushy7
System: windows 10
Battery or AC: battery
Model: ux325
Frequency of occurrence: all the time
Reset OS: yes
Screenshot or video:
Detailed description:I get 7-8 hours at best from my laptop.40% brightness with intel power saving turned on. And just web browsing with chrome
its been like this for 2 months and not really good enough for a laptop that promised upto 22 hours!!
13 REPLIES 13
Blake_ASUS
Community Legend II
Hello rushy7,
Please kindly share a screenshot of your task manager to dig in if there is specific program or function that is using more power than expected.
Also, please refer to our battery test detail below. The battery life differs from spec and usage.
"Battery tests conducted by ASUS on April 3, 2020 using the MobileMark® 2014 Office Productivity scenario. Test configuration: ZenBook UX325JA, 1W FHD LCD panel, Intel® Core™ I7-1065G7, 2TB PCIe® 3.0 x4 SSD, 32GB RAM. Test settings: WiFi enabled, the display brightness set to 150cd/m2, NumberPad off. Actual battery life may vary depending on product configuration, usage, operational conditions and power management settings. Battery life will decrease over the lifetime of the battery"
rushy7
enclosed screenshots thanks
Blake_ASUS
Community Legend II
Hello rushy7,
Thank you for the information.
Then let's run the diagnostic tool in MyASUS, see if there is any problem.
Also, may you run the battery report by cmd ?
rushy7
thanks enclosed report
