zenbook 14 oled
ula
last week I bougt xenbook 14 oled and I`m using it for a week and it`s heating. I mean on computer has really bad overheating. how can fix this
mironmiron
Update drivers and firmware, and use a cooling pad for better airflow.
Also, clean vents and fans of dust and elevate the laptop for improved airflow, consider undervolting, limit multitasking to reduce heat.
Falcon_ASUS
@ula
May I know the product model you are using?
Could you please tell me what program you were running when you noticed the laptop overheating?
How did you determine that the laptop was overheating?
Were you indoors or outdoors at the time? What was the approximate ambient temperature?
If you restart the laptop, does the issue improve?
How to find Model Name
[Notebook/Desktop/AIO] Troubleshooting - Computer Overheating and Fan issues
