Zenbook 13 touchpad's double tap speed.
Innokentiy
Zenbook 13 ux325.
Double tap minimum and maximum speed (which is usually depends on this setting) makes no difference. 😕
Gotta be faster!
7 REPLIES 7
Falcon_ASUS
Innokentiy
https://zentalk.asus.com/en/discussion/comment/219181#Comment_219181
Im running Win11 Pro 64, 21H2 22000.795
@Innokentiy
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Falcon_ASUS
Innokentiy
@Innokentiy
Confirmed by the relevant unit, we use the same laptop for testing, without repeating the situation you described. Since this function belongs to the Microsoft , it does not belong to the ASUS function. We would recommend you report your situation to Microsoft. Sorry for any inconvenience it may be caused.
ASUS_Bot
Rising Star II
