12-12-2019 11:09 PM
12-13-2019 12:40 AM
12-13-2019 01:18 AM
12-15-2019 03:14 AM
rowanj85 posted on 2019/12/13 10:18 Hey Blake The NAS is the only thing i would upload to at that rate. The connectivity drops to the ro ...Hi rowanj85, i had the same issue. Got to the device Manager. then go onto the Intel ax adapater and jumpo to the mimo energysaver Setting. If smps is activated then deactivate it and try if it works. greetz timo
12-15-2019 10:17 PM
timon_MML9 posted on 2019/12/15 18:14 Hi rowanj85, i had the same issue. Got to the device Manager. then go onto the Intel ax adapater a ...Thanks. I modified a regkey to restore PCI link state to advanced power options and disabled power saving on the PCIe. seems to have done the trick. might try disabled smps instead and see which works best.
